headlight help plzzzzzzzzzzz
Old 10-03-2008, 05:14 PM
zilliboy's Avatar
Default headlight help plzzzzzzzzzzz
hey does n1 knows why my right head light doesnt work wen in low and both work on high???
i have a 98 civic ex
Old 10-03-2008, 05:15 PM
zilliboy's Avatar
both light are good
Old 10-03-2008, 07:10 PM
Double check the bulb. Maybe even switch the bulb to the other side and see if it works there. Make sure the bulb connector is not melted.
Most earlier models have 4 fuses under the dash, one for right low, one right high, one left low, one left high. So if the right low fuse is blown, that beam wouldn't work though everything else would.
Old 10-04-2008, 12:17 AM
I had this problem and I looked at the bulb and one of the prongs on the bulb came off the bulb.
Also, it might be the fuse for that beam on that headlight. Each beam per headlight has its own fuse on the under-the-dash fuse box.
I bet you $100 it's one of the two things I listed that is wrong.
Old 10-04-2008, 03:28 PM
zilliboy's Avatar
yoo thx ill check that fuse box i juss checked the one under the hood
didnt know about that1 and yeahh the bulbs are new i bought llike 2 or 3
Old 10-06-2008, 09:06 AM
sittinSideways's Avatar
+2, it' probably the fuse for the beam
rmiller28
07-31-2006 08:18 PM
m00chness
07-18-2006 08:54 PM
civic90power
06-12-2006 06:12 PM
dj_ipirate
10-31-2005 09:12 AM
Quick Reply: headlight help plzzzzzzzzzzz
