I broke that handle to pop hood..
Old 06-28-2009, 12:25 PM
enigma34's Avatar
Default I broke that handle to pop hood..
That hadle you pull to pop the hood, i broke it, gess i pulled to hard on it. what is that part called so i can get a new one.
Also can some one tell me what mm socket is needed to remove the 2 nuts on the upper right engine mount, i need to get that engine damper installed be for the race.
Old 06-28-2009, 12:32 PM
Justin13's Avatar
Banned
i broke my handle too haha
now i have to use pliers
Old 06-28-2009, 12:33 PM
lol my dx had the same thing! the guy busted off handle so i just had to grip wire... ill find the handle again... give me a min...
Click Me Yo!!!!
Old 06-28-2009, 12:54 PM
enigma34's Avatar
mmm looks like hard to install. i hate cables, i thought it was just the handle. the way i broke it was, my hood doesint pop up when you pull the tab, you pull the tab, then lift hood up . ill see if i can use pliers, or use a screw and wire.
Old 06-28-2009, 01:14 PM
yeah i know what you mean i never did mine either.... didnt wanna pay 20 for just that handle... it looks ghetto without it though
Old 06-28-2009, 01:21 PM
its actually not that bad to swap out. pull the kick panel cover off and pull the front inner fender liner out and also pull off the front bumper cover then the 4 bolts on the hood latch itself and pull the cable thru the firewall and remove the handle. pretty easy really.
just mark the hood latch bolts with a marker or something that way you know exactly where the latch was and you can put it back perfectly.
i havent done it yet BUT with my front end damage i had the whole front end ripped apart. so its very easy really. it just looks harder than it really is.
no need to cut up your fingers trying to pull on the cable.
and if you cannt get the hood pull to open the hood then take out the inner fender liner and simply cut the liner and grab the inner wire and pull on it
Old 06-28-2009, 03:02 PM
My hood doesn't pop up when I pull the hood lever either, I have to lift it up after that. Not hard though...
Old 06-28-2009, 03:46 PM
SPLAT's Avatar
Very common thing with your year civic.
Old 06-28-2009, 04:37 PM
ej6buddy's Avatar
Easy replacement, might as well do a hood cable relocation as an extra security deterrent while you're at it.
Old 06-28-2009, 04:47 PM
enigma34's Avatar
Thanks.
Can some one tell me the size socket for the nut on the right upper engine mount?
Quick Reply: I broke that handle to pop hood..
