I need to fix my outlet/cig lighter thing - How do I remove the panel to get inside?
Old 12-24-2007, 01:53 PM
Steven T's Avatar
Default I need to fix my outlet/cig lighter thing - How do I remove the panel to get inside?
Just bought a USB charger thing that pops in. I dont know what the deal is but it doesnt work. It's loose and wiggles around.
I need to remove that panel and investigate inside.
How do I remove this panel?
Easiest way without breaking stuff.
Old 12-24-2007, 08:10 PM
baker's Avatar
Default RE: I need to fix my outlet/cig lighter thing - How do I remove the panel to get inside?
what year is your car?
Old 12-24-2007, 09:05 PM
he has a 98 EX coupe
https://www.hondacivicforum.com/m_52.../tm.htm#525461
Old 12-25-2007, 10:14 AM
Steven T's Avatar
Yah it's 98..
Anyone??
Old 12-25-2007, 02:44 PM
Not really sure what is loose. Are you referring to the accessory socket? If so, have you also checked whether fuse 27 in the under-dash fuse/relay box is blown?
The picture may help with accessing the accessory socket.
Old 12-25-2007, 05:45 PM
Bonestock98's Avatar
I'm having an issue with mine swivelig. Is there anything that could be tightened to fix it? sorry for hijacking your thread.
Old 12-25-2007, 08:15 PM
bp4131017's Avatar
you take that panel off by two screws pointing straight upright above the plug in, and then two other screws on the side, one on each side. pointing towards the middle
Old 12-26-2007, 12:01 AM
that_guy5's Avatar
every once in awhile mine gets loose to [the socket thing] but i just stick my hand behind the panels where the air comes out on the feet side and tighten that thing up
Old 12-26-2007, 12:05 AM
d_reyes's Avatar
i am curently getting my 96 civic painted dark black and i was wondering what rims i should get, should i get black with a chrome lip or just chrome and what size should i get them
zeplin
10-23-2008 09:05 AM
gjitsu
04-23-2008 07:21 PM
addiction2bass
02-10-2008 10:55 AM
curlybandit
07-18-2007 01:25 PM
w8lifter21
03-19-2006 03:11 PM
Quick Reply: I need to fix my outlet/cig lighter thing - How do I remove the panel to get inside?
