JDM D15b VTEC turbo or JDM H22a
Old 05-13-2007, 04:31 PM
4doorcivic9's Avatar
Default JDM D15b VTEC turbo or JDM H22a
Ok I have around $3500 and IDON'T want to go any B-series.I was wanting to do either a STOCK JDMD15b Vtec LSD tranny with Garrett SC-61 turbo, FMIC,Blitz BOV, 3"exhaust etc.just basically a custom turbo setup running about 8 p.s.i on a really good Hondata street tune.OrshouldI go for a STOCK JDM H22a LSD trannywitha clutch/flywheel, I/H/E?
This would be going in a EG.
JDM H22a is going to cost me $2900 for everything, entire swap, motor mounts, axles, shifter/shift linkage etc.
Or I could buy a new JDM D15b VTEC for $800 and custom turbo it
Which Should I do?!?!?
Pro's and Con's if you'd like as well.
Old 05-13-2007, 04:49 PM
Marty's Avatar
Default RE: JDM D15b VTEC turbo or JDM H22a
h22
Old 05-13-2007, 04:58 PM
kokasian's Avatar
the D is going to be easier to swap . The h22 is going to need some other misc. stuff on top of the cost of mounts. For 3500 you could build a d and turbo it compared to the h22, where you might luck up and be able to afford i/h/e after the swap is complete
Old 05-13-2007, 05:45 PM
riceburner700's Avatar
i would go with an h22. you could get the motor and installed for around 3500
Old 05-13-2007, 05:52 PM
Lost's Avatar
Id toss in the H and have a nice N/A set up.
Old 05-13-2007, 08:15 PM
Chopsta's Avatar
H22 definitely, just make your own BOV sounds when you shift, your friends will love it.
Old 05-14-2007, 09:05 AM
1c1v1c1's Avatar
H22 but make sure u get the H22a not the H22a1
Old 05-14-2007, 09:22 AM
drbyers's Avatar
JDM H22a from street imports.
they'll provide you everything you need, including new axles, header and motor mounts.
all for $2,500 or less.
Old 05-14-2007, 09:28 AM
Marty's Avatar
ORIGINAL: 1c1v1c1
not a big difference really other than the jdm counterpart has a lsd in the transmission
Old 05-15-2007, 01:48 PM
Thats where im getting it from. is street imports.
Quick Reply: JDM D15b VTEC turbo or JDM H22a
