Neebie Help Crank Bolt !!
Old 03-08-2009, 08:34 AM
rdg's Avatar
rdg
rdg is offline
Default Neebie Help Crank Bolt !!
Please can you confirm regular left hand thread on the crank bolt removal. I have bars and bolts in the pulley holes to keep the engine from turning and this thing does not want to break loose. I have a four foot pipe on a 1/2 drive ratchet and it won't budge. Just wanted to make sure this comes off in the same direction as all regular bolts.
Thanks for the thoughts
Bob
Old 03-08-2009, 08:42 AM
rburch77's Avatar
yes its a right hand thread! so righty tighty lefty loosey!
Old 03-08-2009, 08:57 AM
It may also help to soak the crank pulley bolt in PB Blaster prior to attempting removal. Don't damage the crank pulley with those inserted bolts. The special hex tool is a safer bet.
Old 03-08-2009, 11:39 AM
97hxt's Avatar
use an high powerd air gun thats what i did
Old 03-09-2009, 09:33 AM
Air gun is best.
If it's a manual transmission, you can prevent the engine from turning by shifting into 4th gear and either have someone hold the brake pedal down or put something in the slot of the brake rotor(s) so the wheels can't turn. Putting bolts in the pulley holes is likely to bend or break something.
Old 03-09-2009, 09:47 AM
vtecaddict's Avatar
good luck to you to get it off. i had to use an I-R impact wrench that hits 900 ft/lbs and it still had some difficulty. PB blaster works wonders.
heres the special hex tool Ron was talking about.
http://www.amazon.com/Alltrade-64879...0085561&sr=8-1
zerojett
10-18-2011 03:01 PM
bronxbomerss2
08-12-2011 03:25 AM
mpatt07
01-14-2008 09:05 AM
oldmoline
10-17-2007 03:51 AM
ray90813
01-10-2006 05:44 PM
Quick Reply: Neebie Help Crank Bolt !!
