Oil Pan or Oversize Plug, that is the question...
Old 05-02-2007, 08:46 PM
Impreza WRX's Avatar
Default Oil Pan or Oversize Plug, that is the question...
Advance Auto has oversize plug, but eBay has Oil Pan. Plug costs way less, is less problematic to install, but metal shavings... [:'(]
Which is better?
1993 LX D15B7 4AT
Old 05-02-2007, 08:55 PM
danomatic93's Avatar
June 2010 ROTM
Default RE: Oil Pan or Oversize Plug, that is the question...
pan
Old 05-02-2007, 08:58 PM
'splain
Old 05-02-2007, 09:19 PM
June 2010 ROTM
k, in the long run, it will make things easier. When rethreading anything, it's very easy to mess it up. If you successfully rethread it, it may not be straight thus not having the best seal. Plus, if you ever somehow lose the oversized plug or someone else does, you or they might forget about it and won't be able to find the right size plug to fill it. And don't forget about those metals shavings too.[:@]
A new pan will alleviate you of all of those worries. But, hey, it's your car and you may not worry about a single one of those issues. Best of luck!
Old 05-02-2007, 10:32 PM
Well, remember this car is like all busted up, so I am free to use any means necessary that does not cost any $$ to fix it, just so it uns long enough for me to get enough $$ to get another car...
Old 05-03-2007, 07:54 AM
mlobitz's Avatar
Member
the shavings should run out with the oil, how difficult is changing the oil pan on these, do you have to remove the engine?
Old 05-03-2007, 12:12 PM
that guy's Avatar
I believe that all of the bolts are on the bottom of the engine for the oil pan. Use the search feature to see if there is any help in any other threads. I know Forty04 had to pull his off when he blew his turbo'd y8. some of those pictures from that thread might come in handy.
meanwhile, you can be sure that it will run if you replace the oil pan, and it's not expensive enough for you to get into debt over. especially if you do it yourself.
Old 05-03-2007, 03:33 PM
To remove the pan you have to remove the downpipe first, and that is a real P.I.T.A. to get off without damaging it!
Old 05-03-2007, 03:55 PM
that guy's Avatar
others have done it successfully, though I can't say I have on a Civic. I'm sure it's similar to removing the o2 sensor. there's no way to do it but to do it carefully.
qandc
03-24-2012 08:13 AM
ic892003
20
08-21-2008 03:40 PM
oilltd
06-10-2008 04:06 PM
theredsuit
08-13-2007 01:52 PM
Quick Reply: Oil Pan or Oversize Plug, that is the question...
