Ok, i am now running Synthetic
Old 04-28-2007, 08:26 PM
Default RE: Ok, i am now running Synthetic
i always use synthetic on all my cars. and fram filters do just fine. spend the extra few bucks it'll be worth it.
Old 04-30-2007, 12:01 PM
mlobitz's Avatar
Member
I watched an episode of Horsepower on Spike, where they dynoed a car, then changes all of the fluids to Royal Purple full synthetic and re-dynoed. If I remember correctly the car made an additional 15 HP.
Old 04-30-2007, 12:42 PM
ej6buddy's Avatar
ORIGINAL: mlobitz
that's because they changed more than just motor oil, they changed pretty much every kind of fluid except for brake fluid, you will see proportionate results for any vehicle of the same age and same type. What you saw was for a truck, which are assembled with "high impact" fluids, meaning they aren't for performance, but rather for towing and loading, and hauling equipment, you won't see any results in a civic with just motor oil. The only way to see any results is if you are running the car with absolutely no oil, and then switch to whatever type of oil you choose.
Old 04-30-2007, 06:15 PM
Impreza WRX's Avatar
Er, I don't think the engine will run without oil...
BTW, I use Valvoline 5w30, but I will go to Pennzoil Synthetic if I hear any good reports about. I got to make the oil last longer than 2,500 miles...
...and no, I am not using 10w40!
From what I remember, the problem with synthetics used to be that the seal swelling rates were wrong, and this is why mixing oils would cause engine failure or seal leakage, but modern synthetics have the same swell rate now as the conventionals, making it less problematic to switch.
Old 04-30-2007, 06:17 PM
that guy's Avatar
ORIGINAL: Impreza WRX
I think that was the point ej6 was trying to make.
Old 04-30-2007, 09:30 PM
synthetic all the way!
Old 04-30-2007, 10:06 PM
ej6buddy's Avatar
ORIGINAL: that guy
thanks, i was just being hypothetical, but thanks for the smart remark. I'm just getting tired of beating this thing to death.
and secondly, sometimes, synthetic isn't the best option for your application. On some cars, synthetic oil is actually harmful for the seals in the engine and drivetrain. but not all cars
Old 04-30-2007, 10:10 PM
cyberx32's Avatar
Syntethic oil is bad for new cars that the engines havent been broken into yet.
DaysOfNoah
06-17-2013 09:13 AM
SirTealingstonThe2ND
12-15-2007 08:12 AM
Scroder
09-07-2006 03:30 PM
Skrapdoggydog
07-23-2006 11:13 AM
Purple Wurple
12-07-2005 04:17 AM
Quick Reply: Ok, i am now running Synthetic
