Time to Replace Tires
Old 03-25-2009, 08:06 AM
Flyboy's Avatar
Default Time to Replace Tires
I have 60,000 miles on my 06 Civic Coupe and the stock Bridgestone tires have held up well. I wouldn't buy them again, but that is another thread.
One is just at the wear bar and the other 3 are not far behind.
I have always bought Michelin Tires and was looking at the Michelin Primacy MXV4 tires.
http://www.michelinman.com/tires/lux...specifications
Do you think this is overkill?
They come highly recommended and for the highway and city driving I do, I think they would go 80,000 miles with no problem.
Without buying any type of racing tire, what regular tire would you guys suggest?
Also, I am thinking of going to either a 215/55R16, or a 215/60R16. The stock size is 205/55/R16.
Would I have any problems going up one size to a bigger and one size up to a wider tire with the stock factory rims and wheel covers?
Thanks in advance.
Old 03-25-2009, 08:10 AM
for tires get them online, should be cheaper. sites i recommend is tirerack.com and discount tires. i would recommend the general altimax hp a good set of tires for me and got excellent reviews on tirerack. and i would also recommend the bridgestone potenza re960, great tires for me also
Old 03-27-2009, 05:40 PM
BANKSBaker's Avatar
You use a tire tread depth gauge to check the tread depth and it is less than 2/32 of an inch, which for most states is the legal limit that defines when a tire is worn out. If you don’t have access to a tire tread depth gauge, you can insert the edge of a coin into the grooves of your tires in several places and observe how much of the coin is covered by the tire.
__________________________________
tips: always check running board mount kit
remy
08-15-2008 08:13 AM
kikaSI
11-13-2006 11:52 PM
silverbullet
04-23-2006 07:19 PM
CivicUnrest
12-04-2005 01:32 PM
stick only
11-07-2004 06:39 PM
Quick Reply: Time to Replace Tires
