What are the differences between DX & HX?
Old 03-30-2007, 12:27 PM
mustangphil302's Avatar
Default What are the differences between DX & HX?
Besides the wheels what are other differences? I don't see too many HX's and I have a chance to buy a bunch of parts off of one. Does it have power steering, is the interior different? Thanx, Phil
Old 03-30-2007, 03:00 PM
cderalow's Avatar
Default RE: What are the differences between DX & HX?
engine & transmission
The HX uses the D16Y5, which is a vtec-e motor
it is designed for high fuel economy, and as such, comes with a different gearing set for the 5 speed transmission, and rather than a traditional automatic transmission, a continuously variable automatic.
interior, body, pretty much everything else should be the same as any other coupe (DX or EX), with the exception of the exhaust perhaps, though I believe the HX/LX/DX share the same exhaust setup even though they don't share the same engines
(HX D16Y5, DX/LX D16Y7)
so in other words.... stuff on the engine may or may not be the same, stuff with the transmission definitely won't, and stuff inside/outside should be
Old 03-30-2007, 03:04 PM
Thanks that helps. I'mjust trying to find out if I can strip entire P/S system (if it even has it)and bolt it up directly to my car.
Old 03-30-2007, 03:33 PM
cderalow's Avatar
p/s? power steering?
should be able to take the power steering off a HX and put it on a DX
Old 03-30-2007, 03:59 PM
Yeah, I can't stand manual steering. It drives me insane.
Old 03-30-2007, 04:48 PM
Ben's Avatar
Ben
Ben is offline
DX also doesn't come with an a/c.
Old 03-30-2007, 04:55 PM
blackmetal619's Avatar
and dx doesnt have power door locks, or power windows, or a tach
Old 03-30-2007, 05:11 PM
Noneed forA/C, don't need to weaken that little motor any more. And my DX came withpower door locks and a tach.
Old 03-31-2007, 12:57 AM
Ben's Avatar
Ben
Ben is offline
ORIGINAL: mustangphil302
You make it sound like a lawn mower.....unless you're looking to run the a/c down the strip its great to have in the summer......not to mention you don't always have to run it.
Old 03-31-2007, 02:54 AM
WhiteRabbit1021's Avatar
Power steering robs more power than A/C. And that's running 24/7.
Quick Reply: What are the differences between DX & HX?
