2003 transmission issue
I recently put a new motor in my 03 civic LX, I put a stage 3 clutch in and new axle shafts. I went to drive it home and I got about 5-7 miles and heard a pop and then I had no drive at all from my transmission. I noticed that the passenger shaft had popped out about 1 1/2 to 2 inches. I got it home and put the shaft back in, checked the other side as well and I still have no movement. I was refraining from putting in more gear oil until I figured out what was wrong. Need some ideas on what to check? Does the transmission need oil in order for it to work? (for testing purposses) I'm lost and I don't really know what to check. Please help
Not much oil will come out when the shaft comes out, so just top it up again. Do not use heavy (80W / 90W) gear oil in Honda manuals. Make sure the shaft is all the way in and locked, which will take some force. If it comes out again try a new spring clip on the end.
mudhenFUF
01-16-2023 08:43 PM
redraif
03-07-2013 01:59 PM
ryanhoangle
06-20-2008 09:35 AM
