94 Civic. Few problems
Old 05-01-2013, 01:50 PM
Exchanged's Avatar
Default 94 Civic. Few problems
I have a 94 Civic, D16Z6. I have a low idle (around 200). My gas mileage has tanked, and I have bog or hesitation to accelerate under 2500rpms in any gear. It's really hard to describe but its like the engine is gasping for air.
I'm guessing that all the problems are linked somehow. I have changed my IACV and my PCV valve (that was stuck), and none of the problems have seem to have gotten better. As a college student I cant throw money at it to see whats wrong with it. I've done some reading and my fast idle valve? could be one of the problems with it. I just havent gotten around to it. The only mod on the car is a cold air intake.
Any help/suggestions would be very appreciated. Thanks in advance.
Old 05-01-2013, 02:22 PM
Check the spark timing. If it's way off, timing belt may have skipped.
Old 05-02-2013, 05:12 AM
Also make sure your air filter isn't clogged up or wet (since you have a CAI)
Old 05-04-2013, 01:21 PM
Exchanged's Avatar
Ill check the timing this weekend. Just cleaned the air filter not that long ago so that's ruled out. Thanks for the replies.
Old 05-04-2013, 03:01 PM
make sure it's also not wet.
Old 05-07-2013, 11:51 AM
When were the spark plugs, plug wires, distributor cap, and rotor last replaced?
crispydwight
12-15-2010 07:05 PM
paulb16
07-23-2007 11:44 AM
wheeels302
02-26-2007 02:24 PM
Quabbdude
04-27-2006 03:31 PM
redtide265
03-22-2005 11:06 AM
Quick Reply: 94 Civic. Few problems
