98 Civic EX transmission
My civic has been running fine w/o any troubles. I took it to a shop that had a coupon for a cheap engine oil change. After picking up my vehicle I made a couple of stops then headed home. On my way home on the freeway the engine started to slip whenever I pressed on the accelerator. Also noticed a violent vibration when idling or at lower speeds.
Is there any common mistakes that the shop could have done while changing my oil?
Or is this purely coincidence and my transmission is starting to go?
Thank you for your input.
Hondabuyer
01-25-2012 06:45 PM
Amanda
03-11-2005 01:39 PM
98brokeassvtec
08-23-2004 05:24 PM
slideman99
08-03-2004 06:10 PM
1998, 98, civic, civic 1998, code, conspiracy, honda, oil change, problems, slipping, trans, transmission, transmissions
