98' DX idle surge random misfire iacv? ficv?
Old 12-18-2014, 12:14 PM
lcynck's Avatar
Default 98' DX idle surge random misfire iacv? ficv?
recently bought older civic 180k,
recent shop tune-up w/timing, belts chged.
P0304, but one instance of P0300, 0301, 0302 each too.
trying DIY, cleaned IACV... apparently no EGR w/ DX.
started fine afterward, for 5-6 min till warmed up...
then idle surge... unplugged IACV and it seemed to idle fine...
is this simple evidence to replace IACV or should I
address 'fast idle valve' somehow before ordering replacement?
Any other things to check first? or as well?
( did compression testing... 1912, 170, 185, 180)
Old 12-18-2014, 04:31 PM
Does the car drive OK other than not idling smooth?
Check that the radiator is full (when cold). Coolant sloshing around in the engine can cause an unsteady idle.
Old 12-18-2014, 06:01 PM
lcynck's Avatar
There's is a noticeable lack of power when the misfiring occurs
after being warmed up... so I'm not driving it until I can fix this
and looking for relatively simple DIY checks...
The car obviously not worth much but was a great runner at 38-40mpg.
Any suggestions much appreciated.
Old 12-18-2014, 06:09 PM
lcynck's Avatar
A while ago, the coolant was low in reservoir and possibly in engine for a bit,
fixed with adding coolant and burping, maybe 3-5k miles before problem
occurred. Coolant is full in radiator when cold.
Old 12-19-2014, 04:11 PM
If it misfires while driving, especially heavy throttle and low rpm, that is usually weak sparks-- and the spark wires are a prime culprit. Some aftermarket wires are really bad and only last a few months.
Old 01-16-2015, 03:16 PM
lcynck's Avatar
Default followup: 98' DX idle surge random misfire iacv? ficv?
fyi...
put in new iacv -> fixed surging idle, but not misfires...
installed OEM spark plug wires (NGK 8034 HE76),
(and new spark plugs denso(4504) PK270TT)
This fixed misfires/power loss, so car running fine! :-)
thanks for replies... appreciated
note: there was 30k miles on old plug wires
labelled "STI Spark Transfer International"
TGriffin
09-29-2011 03:43 AM
jlor010
08-08-2010 06:21 AM
jonsaidthat
07-01-2010 05:48 PM
jamisonh
02-21-2009 10:17 AM
northwoods
06-15-2008 07:12 PM
Quick Reply: 98' DX idle surge random misfire iacv? ficv?
