Awful Noise
Old 02-27-2008, 12:16 PM
crimsonnblue's Avatar
Default Awful Noise
Lately I have been hearing this noise from the car. It is a grinding, hum. It does it when the engine is cold and @ 1800 rpm around 40mph and @ 3100 rpm around 75 mph... Its consistent at this point in this RPM range.
It also makes this same noise when I first start the car. Very cold engine, at a stop light.. hummmmm/grind.. Pretty awful noise. Cant pin it down in Park. Only in gear will it make this noise.
I will also add that the noise sounds metallicy...
Old 02-27-2008, 12:54 PM
Live_4it's Avatar
Default RE: Awful Noise
Does it still happen once the car is warmed up to normal operating temperature? It sounds like a heat shield rattle to me, mine does it as well. I even ripped off the bottom part of it and the piece at the top still does it.
Old 02-27-2008, 12:58 PM
+1
Old 02-28-2008, 05:23 AM
Yeah. It does it still once it's warmed up.... Whats odd is that it is scary consistent at those RPM ranges.
Old 02-28-2008, 08:10 AM
gin0o0o's Avatar
Go under the car and check your heatshields. That's most likely what is causing the annoying grinding noise at the certain rpm. I had the same problem and just removed the old rusted heatshield right where the headers connect to the exhaust.
DeanHensler
14
06-14-2017 06:44 PM
01silverbullet
06-12-2008 09:28 AM
marcin69k
05-25-2007 04:25 PM
Squeek
05-22-2004 12:32 AM
Quick Reply: Awful Noise
