Sponsored by:
Sponsored by:
Car keeps stalling when I come to a stop when engine is warm
Old 10-06-2014, 05:56 PM
joenobodyyet's Avatar
Default Car keeps stalling when I come to a stop when engine is warm
I have a 1997 Honda Civic LX. A few months ago my check engine light was on and I had cylinder misfires, so I had new spark plugs installed with new wires and a few days later the Check Engine light went off. About 2 months ago I noticed the Check Engine light came back on. I went in for an oil change and they notified me that I had a broken axle boot (that wasn't urgent) and an oil leak definitely around the valve cover. They also read the codes from the Check Engine Light. Last week I installed a new valve cover gasket, and the leak doesn't seem as bad, if existing at all. Since my oil change I've been having a new issue.
When I first start the car in the morning, the car runs fine. Only when the car is WARMED up do I have an issue where the car stalls when I come to a stop. If I press the gas pedal it will not stall, but if I come to a stop it very often turns off/stalls and I have to turn the key and start the car again. It always starts up right away. When the car gets warm and I can tell that I might stall, I've also noticed that the steering of the car gets slightly stiffer. But again, when I run the car cold, it runs great. I also never feel misfiring like I did before I changed my spark plugs. The check engine light is on and here are the six codes that I got when I got my oil changed:
p0171 Air/Fuel Mixture System Lean Bank 1
p0301 Cylinder Number 1 Misfire Detected
p0302 Cylinder Number 2 Misfire Detected
p0303 Cylinder Number 3 Misfire Detected
p0304 Cylinder Number 4 Misfire Detected
and -p1300
If anyone has any advice on where I should look to detect the issue, that would be appreciated! Thanks!
trainmap
03-22-2012 02:31 PM
belfort30
05-19-2011 04:52 PM
jay-saul
02-26-2009 09:37 AM
blahwoop
06-25-2007 10:27 AM
96EX_NC
08-28-2004 07:57 PM
Quick Reply: Car keeps stalling when I come to a stop when engine is warm
