coolant in valley that surrounds all cylinders?
Old 09-05-2013, 05:28 PM
redsox4020's Avatar
Default coolant in valley that surrounds all cylinders?
I blew a head gasket and when I removed cylinder head the open deck set up has a valley that runs all around every cylinder and its full of coolant all the way top of the cylinder wall I have never delt with a open deck engine is this normal to have coolant surrounding all the cylinders?
Old 09-05-2013, 07:40 PM
That's how every water-cooled engine works. The coolant surrounds the cylinders in a "water jacket" topology to keep them cool.
When you only drain the system through the radiator, there will be quite a bit of coolant left in a Civic engine. They have a block drain plug to let the rest of the coolant out.
Old 09-06-2013, 02:46 PM
redsox4020's Avatar
just so I know we are talking about the same thing im talking about where the arrow is that that runs all along the cylinders is filled with coolant all the way flush with the cylinder walls. where the X is I know are coolant passages and are suppose to have coolant in them. thanks again for the reply im just tryig to make sure....
[IMG][/IMG]
Old 09-06-2013, 05:31 PM
Yes, coolant belongs there.
Note that if you removed the head without draining any coolant at all first, it's likely that some of the coolant spilled down the oil return holes in the front corners of the block and is now in the oil pan. In which case you should change the oil before trying to start the engine again.
atlantahonda
06-07-2010 06:51 AM
Jesse_M
07-31-2008 02:33 PM
ozzierod
11-21-2005 02:21 AM
paradigm1980
06-29-2005 09:57 AM
FlyGLi
07-24-2004 10:22 AM
Quick Reply: coolant in valley that surrounds all cylinders?
