It cranks but wont start, HELP!!!!
Old 07-11-2006, 12:59 PM
Civicracer2910's Avatar
Default It cranks but wont start, HELP!!!!
I have a 93 civic DX, it has a 1.5L d15b7 non-vtec its was running fine and then when i was driving it it just died all the sudden!!!!! and now it wont start back up and its not gettin fuel. ive replaced to pump and filter and it still wont start. so if anyone has sum suggestions as to what it might be PLZZ let me know!!!! Thanx
Old 07-11-2006, 01:23 PM
fglaustin's Avatar
Default RE: It cranks but wont start, HELP!!!!
could be that main EFI relay.
also, there should be a fuse for the fuel circuit. don't know where it is in mine (88 civic) and dont know where it is in yours. (check the fuse first)
take the fuse box off, and see if on the back of it , it shows a fuel (main efi) fuse.
or it could be out under the hood in a box.
Old 07-11-2006, 02:23 PM
Ya all the fuses are good i went through all of then inside the engine bay, and the fuses under the dash.
Old 07-11-2006, 02:34 PM
fglaustin's Avatar
i don't know when they started it - but there is such a thing as a roll-over switch that is put on cars so that if you are in an accident and the car turns over, the fuel pump is cut off by this switch.
does your year have that ???
Old 07-11-2006, 02:37 PM
im not sure because in the manual that i have it doesnt say anything about one, and when i was lookin inside the car (under the dash and back where the fuel tank is) i didnt se one so was assuming that it doesnt have one
Old 07-11-2006, 02:56 PM
fglaustin's Avatar
did you put 12 volts directly off of the battery after you took the old fuel pump out ??
(i always do - make sure one is not replacing something that does work )
Old 07-11-2006, 03:02 PM
chriskatana's Avatar
Main Relay
http://techauto.tripod.com/mainrelay.htm
________
K engine
Old 07-11-2006, 03:24 PM
no i havnt tryed right off the battery, and thanx chriskatana i will give that a try and see if that works.
frankV
05-13-2011 05:02 AM
WishIhadVTEC
01-18-2011 04:57 AM
tj1114
01-14-2011 09:02 AM
hamorhead
01-29-2009 10:45 AM
black99ta
08-02-2005 05:24 AM
Quick Reply: It cranks but wont start, HELP!!!!
