Help Please
Old Jan 30, 2007 | 10:51 PM
birdmane's Avatar
Default Help Please
I just bought a 91 civic hb today and the person i bought it from told me he thinks it needs a new clutch cable, but a mechanic told me it probly has somethin to do with the tranny but he has not looked at it. The problem is that when i press on the clutch it does not disengage if i start it in 1st it will start moving no matter how hard i press on the clutch. I need to get this car running for work by tommorow so please give me any information you might have for me thanks.
Old Jan 30, 2007 | 10:59 PM
98civex's Avatar
Default RE: Help Please
is there resistance when you press the pedal or does it just easily limp down?
Old Jan 30, 2007 | 11:03 PM
birdmane's Avatar
yes theres resistance i press it down and it springs back up i also had my girl press it down and it pulled the arm thing up on the tranny
Old Jan 30, 2007 | 11:49 PM
Misha's Avatar
Sounds like clutch cable needs adjustment. Any grinding when you shift?
Old Jan 30, 2007 | 11:59 PM
birdmane's Avatar
not really sure bout the grinding but how do you adjust the cable
Old Jan 31, 2007 | 12:57 AM
Misha's Avatar
Turn the nut at the clutch end of the cable
Old Jan 31, 2007 | 12:11 PM
birdmane's Avatar
I tried to turn it as much as possible and i keep trying to start it and push the clutch in then put it in 1st but its like theres a wall there and when i try to put it in reverse it just grinds
Old Jan 31, 2007 | 12:55 PM
TheShimster91HB's Avatar
Ihave the same car and the same problem. I found that part of the clutch pedal hadsnapped off where it connects to everything else. So when I push down the pedal it moves the stuff its conected to as well as the pedal itself, therefore not disengaging the clutch fully. This was the result of -48 C weather turning my car into an icecube making everything brittle and easily breakable. I hate winter.
Old Jan 31, 2007 | 01:05 PM
birdmane's Avatar
so where am i looking for that broken part? If you could show me with a pic or give memore detailed info that would be great thanks
Old Jan 31, 2007 | 02:33 PM
birdmane's Avatar
alright i just actually drove it for the first time around the block it seems like it needs a new clutch but heres whats going on i cant start it in nutural or i wont be able to put it in 1st , so i start it in 1st then i freestyle shift or whatever you call that when you put it in 2nd with out the clutch and in second it doesnt get any power so im thinking it needs a new clutch but that still doesnt erxplain why i cant disengage the clutch when i press the clutch pedal. maybe the pressure plate also needs to be replaced? im not sure let me know what you think.
