high suction pressure with low discharge pressure
Old 07-10-2011, 12:56 PM
lunger's Avatar
Default high suction pressure with low discharge pressure
I changed my compressor out after hearing the pulley bearing grinding a bit. However when I serviced the system my low side pressure was 110 and the high side pressure was 200. I recovered the system and changed the expansion valve thinking it was clogged but after re-servicing I'm still getting the same numbers. The compressor is running with clutch engaged but there is no noticeable change at the vents.I'm wondering if the compressor I got has bad valves in it or a clogged low side line. Anyone with any possible solution would be greatly appreciated.
Oh I changed compressor or due to my puller distorted the pulley taking it off and now it will hit the field coil so I spent the extra few bucks over a clutch rebuild kit and got a new compressor.
Old 07-10-2011, 02:50 PM
If you have a full charge in and are using the manifold properly (both handwheels CLOSED to measure pressures), I'd say the new compressor is a dud.
alfred_dr
02-10-2011 07:09 AM
Mahones
06-04-2007 05:04 AM
tuolumne
01-12-2007 07:22 AM
TheMoogly
12-30-2006 12:22 PM
liliechen
12-25-2005 11:15 AM
Quick Reply: high suction pressure with low discharge pressure
