Car Won't Start - Mystery
I have a 95 Civic CX, SOHC engine, 1.6L....A few weeks ago my civic started to run only on two cylinders (cylinders 1 and 4)...couldn't figure out what was causing the problem so I was going to bring it toa garage and a few days ago I went to start is and it will not start. The car turns over like normal but it just won't fire. Checked the spark plugs, they are all firing andthe fuel pump is working.
Does anyone have any idea what could be the problem?
Thx
Thx
RE: Car Won't Start - Mystery
ORIGINAL: wes94si
pull compression check , if you are getting fuel and enough spark
Another option is that you may have clogged injectors. Run the compression test first, and post your numbers. If those are good, that my guess is that you've got clogged up injectors
94VTECoupe
06-23-2007 11:47 AM
forrealb50
15
11-12-2006 01:52 PM
