P0335 code, crankshaft position sensor problem
Old 03-24-2013, 05:03 AM
LSUfan71's Avatar
Question P0335 code, crankshaft position sensor problem
My daughter's 2000 Honda Civic EX stopped running recently, it would turnover but wouldn't start. I figured it was the distributor. I installed a reman distributor from AutoZone with a new cap/rotor and new sparkplug wires. The car started but it was running a little rough with a CEL.
I drove it down to the AutoZone and they checked the code, he says it was P0335 (CKP sensor "A" no signal). I was previous unaware where the CKP sensor was located and he priced one fairly cheap so I bought it to install after I got back home. What he sold me, as I later learned, was actually a crankshaft speed fluctuation sensor (CKF) Duralast/Crankshaft Position Sensor (SU4087) | AutoZone.com.
So is it mislabeled in the manual or on AutoZone's website? In the manual I found a test for the CKP sensor on the 'new' dizzy so I'll do that later today. Thoughts? Is the code actually for the CKP or CKF?
Old 03-26-2013, 07:13 AM
LSUfan71's Avatar
When checking resistance for the CKP I get readings of 11-16 MΩ, depending on reversing red/black probs on the #2 & #6 terminals. Obviously this is above the 350-700 Ω specified by the manual.
I suppose I should swap the distributor at AutoZone. Is it common to have a bad crankshaft position sensor on a new/reman distributor?
Old 03-26-2013, 08:49 AM
CKP and CFK sound like they refer to the same thing. Definitely have the distributor swapped out and see what happens.
Old 03-26-2013, 11:08 AM
LSUfan71's Avatar
Got a new one. I checked it at the parts counter and got 354 Ω, I'll put it on in a few min.
Old 03-28-2013, 07:58 PM
LSUfan71's Avatar
Thumbs up
Runs great, CEL gone.
ejp2fast
03-23-2013 08:15 AM
macchu43
01-29-2008 02:29 PM
hondaguy84
10-28-2007 08:02 PM
quack
11-07-2006 04:23 PM
AnakinKenobe
02-19-2005 05:28 PM
Quick Reply: P0335 code, crankshaft position sensor problem
