Sponsored by:
Sponsored by:
Strange electrical issue
Old 01-22-2010, 07:19 AM
Shiznick's Avatar
Default Strange electrical issue
I have an intermittent electrical issue with my 96 DX 4 door civic. It just started up again so I decided to look on-line. What happens is while I'm driving and I use the brake, my head unit loses power for a split second and has to power on again (causing about a 10 second break in my music). I tried it at night and my head lights will dim a little bit at the same time this happens, again it is just for a split second. This happens when I push in the brake peddle about half an inch to an inch.
Old 01-22-2010, 07:27 AM
Check that the battery connections are secure and not corroded. Check that the ground wire from battery (-) is well connected to the frame and the engine/transmission. When the brake lights come on that causes a surge in the system that the battery needs to handle.
Old 01-22-2010, 07:53 AM
Yo may want to check whether 7.5A fuse 15 is blown under the dash. If that's fine, take the car to an auto parts store to have the alternator checked.
mudhenFUF
01-16-2023 08:43 PM
imer79
10-29-2009 09:34 AM
BurryTheSpeedo
01-14-2007 02:17 PM
Sporange
15
01-12-2007 01:07 PM
drp58
08-02-2005 07:28 AM
Quick Reply: Strange electrical issue
