Lights on Speakers?
Old Apr 17, 2009 | 08:46 AM
with a battery getting drained after a amplifier install, you need to check out the amplifiers terminals and make sure that NO strands of the power wire can touch the remote turn on wire or terminal or even the ground.
even if one tiny hair strand is crossed onto the remote turn on wire or terminal it will keep the amplifier ON overnight which can easily drain your battery... ive done it before
one thing i do to prevent it is put the power wire in first and once its put into the terminal after i do my best to get all the wires inside the terminal then i wrap the wire and terminal with electrical tape to be sure that no other wires can touch the bear wires. after thats wrapped up you do the next wire the same. sure it doesnt look very good BUT theirs no possible way the wires can short out.
amplifiers with the square mounting terminals are hard to get all the strands inplace with no stray wires. if you dont like the electrical tape around the terminals then get some crimp on connectors to crimp onto the wires themselves and then put the connectors into the amplifier terminal. but you still want to be sure that no stray wires on the connectors can touch each other if there is bear wires poking out.
itzcorky
Sep 21, 2011 07:45 AM
TrAvIs 05
Dec 29, 2006 11:23 PM
Sleepin95CivicDX
Oct 6, 2006 11:26 PM
93hbSIgsr
Mar 18, 2006 06:13 PM
xe1002
Jul 10, 2005 12:45 PM
