General Tech Help
Old Sep 17, 2007 | 12:28 PM
jtswift_2000's Avatar
Member
Default RE: General Tech Help.
Hi.
About a month ago I bought a 1998 Hatchback Civic 1.4 Illusion & when I bought it the Engine Management light had been removed & it wasn't until my friend, who's a Mechanic, saw this that he plugged in another bulb in its place to find it was on.
I rang the Garage I bought it from and they have taken it back to plug it into the computer to see what's causing the fault. They say it wasn't them that removed it (I believe them).
My question is, when I start the Civic, I must listen for the Petrol to pump in before I start it. I have to leave it for 3 seconds or so before I turn the key. If I don't it'll turn for about 2-3 seconds before it fires up. The barrell in the ignition had been changed due to lost keys (so I was told), even though I found the new master Honda key in the Fuse box in the Engine bay and it starts the car (I know it's not meant to be used but since the ECU had been "updated" to bypass the Green light for the Immobiliser in the dash,it was ok).
The Mechanic from the garage tells me that I have to leave the Petrol pump through for 2-3 seconds before I start but any other Civic or Honda for that matter that I've started, it has fired up on half a turn or so, even 1st thing in the morning.
Is my Mechanic lying to me?
Any suggestions as to why my Civic won't start on the first turn & why I must leave it for 2-3 seconds before turning the key?
Any help would be much appreciated as I really want this fixed before my 3 monthWarranty expires & to make sure the Mechanic isn't pulling a fast one on me.
Kind regards,
JT
Ireland.
Old Oct 4, 2007 | 02:32 PM
wee eck's Avatar
hi new to the site and would like to know where the heater blower motor is and how to change it and if its a big job as my heater is not working.
Old Nov 21, 2007 | 05:02 PM
H22EC_2005's Avatar
Hey i have a 91 civic si hatch doing a b18a out of a 91 acura integra lsswap i ordered the motor mount kit and its supposed to be simple direct bolt on but the motor mount on the passanger side it sits a little bit to high from the bracket on the chassis and when i push it down the crankshaft pulley hits the chassis on the other side of the car. what do i do. anyone recommend anthing.
Old Dec 14, 2007 | 07:55 PM
wacivickid89's Avatar
So i have a problem and don't know what it is, so we were driving and going about 110 in 4th gear at about 6,000rpm and it redlines at 7, well as we got there the engine like cut out and the check engine light came on,,DO you know why this is?
Old Dec 14, 2007 | 07:57 PM
So i have a problem, i have a 1996 honda civic ex sohc v-tech we were mobin around going about 110mph at about 6,000 rpm in fourth gear.redlines at 7 and so as were going the engine like cuts and the check engine light is on and..then it was still running fine but we tryed to go again in second gear later on and it cut out at about 5,000 rpm's......CAN YOU HELP ME> NO IDEA WHAT IS WRONG
Old Dec 14, 2007 | 08:07 PM
ORIGINAL: wacivickid89
Please drive safely.
You caused the "fuel cut-off control" to kick in (see picture).
You should retrieve the code stored in the ECU to determine why the CEL is ON:
http://www.honda-tech.com/zerothread/1901557
[IMG]local://upfiles/25538/C804CAE30F9744B6B08C0665FE29BFC1.jpg[/IMG]
Old Feb 12, 2008 | 07:36 PM
cairo13's Avatar
is it possible on the new 08 civics to go from the stock 15" tires and rims to racing 17" tires and rims?
if so what need be done to get there?
Old Feb 20, 2008 | 12:24 PM
x1buellster's Avatar
Default 96 civic missfires at 55mph and up and acceleration
can someone help me wth this problem of my 96 civic missfiring at 55mph and up after 20 minutes of warmup and driving
Old Feb 20, 2008 | 12:28 PM
Default RE: 96 civic missfires at 55mph and up and acceleration
Old Feb 20, 2008 | 12:34 PM
96 civic dxsometimesmissfires at 55mph and up after warm upand some times is hard to start in the morning like it is not gettting fuel.
