Short Throw Shifter?
Old Dec 24, 2008 | 11:44 AM
C-lo's Avatar
the poly bushings replace the rubber ones that come stock, they firm up your shifts by a bunch (i.e. reduce play in the shifter and miss-shifts) and they go further down the shift linkage than your actual shifter, like where the shift linkage meets the trans
Old Dec 24, 2008 | 11:50 AM
munkeewrench23's Avatar
they go on the shift linkage on the side where the shifter is located bolted under the car and the other goes where the shift linkage is bolted to the tranny
Old Dec 24, 2008 | 11:55 AM
C-lo's Avatar
oh yeah i forgot about the piece that goes right by the shifter.
the two circular ones fit into either side of the shift linkage down by the trans and the metal bit goes between them. the other one goes right by the shifter where the shift linkage is secured to the bottom of the vehicle (you will see the stock parts that look basically the same anyway, so just swap them out).
Old Dec 24, 2008 | 12:01 PM
Poly bushings are made of polyurethane, a tough type of plastic. They basically eliminate the play associated with the stock rubber bushings. Less play means more of the energy you use to move the shifter actually reaches the transmission, instead of being wasted on compressing the bushings, making the shift a little more efficient.
And here's where the bushings go:
Old Dec 24, 2008 | 12:06 PM
Jimbo&2000SI's Avatar
Thanks a lot guys.
Greatly appreciated.
Old Dec 24, 2008 | 12:13 PM
Oh yeah and what is the difference between a duel bend and a single bend and does it matter which one i get?
Old Dec 24, 2008 | 12:21 PM
1.looks different
2.dual bend i think gives you a shorter shift than a single bend
Old Dec 24, 2008 | 04:51 PM
^also places the shifter closer to you
i like it better than a single bend
Old Dec 26, 2008 | 11:29 AM
C-lo's Avatar
it is a matter of preference really, i went with dual bend so i can position the shifter closer to myself. there should not be a different in how much it reduces shift throw as long as the dual and single bend you are comparing are the same model (i.e. the b&m single and dual shorten the shift by the same amount so whichever suits you is best)
Old Dec 28, 2008 | 09:19 AM
ok thx
redlines4us
Oct 10, 2006 05:02 PM
eLantern
Aug 29, 2006 01:08 PM
mxs
Drivetrain DIYs
Jun 12, 2006 09:51 PM
05CivicLX
Jun 4, 2005 12:46 PM
red_sleeper
Feb 2, 2005 05:20 PM
