94' civic parts compatibility-what works-what don't??
Old Aug 2, 2009 | 06:20 AM
hamorhead's Avatar
Just use the auto and paint over the gear selector
Worked for me
Old Aug 2, 2009 | 10:49 AM
any year from 92-95 cluster with the tach would work its all plug and play. you can keep your cluster it would just show the prnd21 on it thats really the only difference and you can take the light out of it and it wont light up
the ecu i'd take 60$ shipped
or just send me yours and 20$ (not the one from donor car)
Old Aug 4, 2009 | 05:36 PM
mastertech's Avatar
Thx for the help and info- I am gonna start on it this weekend- I will prob send you my ecu- wil get with you later on for the details- do you know where I might find bore/stroke specs? I have ck'd mitchell on demand at work- very limited info- I have the good running 1.5 left over. I wondered if it would be worth building up?
Old Aug 4, 2009 | 06:01 PM
building up ......like to turbo?
Old Aug 6, 2009 | 07:25 PM
mastertech's Avatar
Yeah- I wish, just wanted to find out where the diff is between the 1.5 and 1.6- same block just diff bore/stroke? I will rebuild the 1.5 and if possible- use it for the replacement 1.6 when the time comes- just wondering. FYI- 1.6 is currently running strong with 317k on the engine. the 1.5 runs strong at 143k on the engine.
Old Aug 6, 2009 | 07:28 PM
Wikipedia
Old Aug 6, 2009 | 07:33 PM
whats the engine
d15b7,d15b2,d15b
tell me what it says and illl give you some info on it..
Old Aug 6, 2009 | 08:30 PM
mastertech's Avatar
I will get the info tom- the stock 1.5 is currently running in the 93 donor civic-all original. I wasnt sure of the diff between the 93 1.5 and the 94 1.6 vtech. Like I said in a prior post- I have the complete mitchelle on demand at my shop- the honda section is ok for a repair on exact yr/model. However they dont put them side by side on a spec sheet- bore/stroke etc. I'm taking a shot and saying the blocks are the same- EG- chevy 305/350- same block, bore and stroke makes the diff.
Old Aug 6, 2009 | 08:34 PM
here is the info on all D" series engines
http://en.wikipedia.org/wiki/Honda_d_engine
Old Aug 8, 2009 | 08:08 PM
Honda_man70583's Avatar
Default I have a question
I just picked up a 94 civic coupe auto I have a 98 civic 5spd an was going to part out my 4door always had a thing for the 2doors I bought all the stuff to do the swap was wondering if I had to change the actual mount that bolts to the back of the subframe next to the fire wall or if I could just change the bracket
