B18C1 Swap
Old Apr 24, 2006 | 03:53 PM
  #21
AgentofDarkness's Avatar
Default RE: B18C1 Swap
I called up a junkyard for a B18B. The guy is like $500 w/o the sensors, harness, and ECU. Stuff is too expensive.
Old Apr 24, 2006 | 05:01 PM
  #22
Nail I3unny's Avatar
what is the rod/stroke ratio on a B? C1?
Old Apr 24, 2006 | 09:43 PM
  #23
I want to make this clear, vtec is not now and never will be for performance in any engine. It is so that they can bridge the gap between daily driver freindly smaller cams(the low rpm lobes) and higher rpm cams(the vtec lobes on a vtec equiped engine)
Some of the best bump sticks you can buy for DOHC VTEC engine eliminate vtec all together and are really pricey. Does TODA ring a bell? if not take a look or look here
well, kind of. it would KILL your low end, and you do occassionally use the low end in road racing, though not much with the right gears and if you can drive properly, but youll get there a lot until you are up to a semi-pro level of driving where you are good enough to keep it in the powerband. and as for Toda Vtec Killer cams, that isnt because of any kind of advantage to not having Vtec, just that when you stay in high rpms, like in a full race car, its a trade off to lose a little bit of low end for a little bit less drivetrain mass. it suffers a big loss on the bottom end though. and I would walk a Vtec profile ground Ls swapped car, so they arent equal.
Old Apr 25, 2006 | 02:01 AM
  #24
Marty's Avatar
Actually the VTEC KILLER cams were designed and made for racing series in Japan that you could not have variable valve timing in.
Ratboyz
EK Swaps
Aug 13, 2007 03:59 PM
mentaldis0rder
EK Swaps
Apr 1, 2006 09:45 PM
mentaldis0rder
EK Swaps
Mar 17, 2006 10:21 PM
creative626
Mar 13, 2006 01:02 PM
Splurbyburble
May 3, 2005 05:10 PM
