Which head gasket for turbo'd D
Old Sep 13, 2005 | 07:26 PM
XCM828's Avatar
Default Which head gasket for turbo'd D
Anybody know of good brands with high quality stuff and not too expensive prices, and a place to buy one?
Old Sep 17, 2005 | 04:15 PM
XCM828's Avatar
Default RE: Which head gasket for turbo'd D
Nobody? I've heard good things about Fel-Pro. I've also heard that the OEM gasket should be fine. Please respond.
Old Sep 17, 2005 | 08:46 PM
Pete's Avatar
well uve got 2 options. Take off your valve cover, and install ARP headstuds and use the OEM gasket and ull be fine. Or remove the head of the motor (pain in the ***) get a thicker headgasket to lower compression, then install ARP headstuds. How many LBS of boost u going to run?
Old Sep 17, 2005 | 09:01 PM
XCM828's Avatar
8. Yeah, it's a PITA to take off the head, but if it's necessary I can do it. Keep in mind the cars got 120k, and I'm not sure if it's been the same gasket the whole time. If I take the head off to replace the gasket, I might get it milled too. I've also heard good things about Cometic gaskets.
Old Sep 17, 2005 | 11:27 PM
Pete's Avatar
lots of guys have had 0 problems with stock head gaskets.......if u get those ARP studs......the head will not lift under boost and ull be fine for 8 lbs.
Old Sep 17, 2005 | 11:36 PM
fast93civic's Avatar
awesome, good advice pcupo, ARP studs it is.
Old Sep 18, 2005 | 12:24 AM
Pete's Avatar
BAM! There are my ARPs. Now i just gotta figure out how the head comes off so i can install them.
[IMG]local://upfiles/2201/61EA663611204C869D8C58227F180AB1.jpg[/IMG]
Old Sep 18, 2005 | 11:27 AM
oh crap, the head has to come off, damn, for some reason I thought you would replace the bolts holding the head on with APR's. Well, ok, let us know how it goes.
Old Sep 18, 2005 | 11:58 AM
XCM828's Avatar
I think I read on turbod16 that some people installed them without taking off the head. Where'd you order yours from?
Old Sep 18, 2005 | 04:17 PM
Kappa22's Avatar
ORIGINAL: pcupo12
I believe you actually need to take the HEAD off to install head studs... I could be wrong though
