srs light
Old Sep 18, 2005 | 05:29 PM
blhatfield's Avatar
Default srs light
I would like to know how to reset the SRS light on my 2002 civic EX. Thank you
Old Sep 18, 2005 | 05:37 PM
chaseman1978's Avatar
Default RE: srs light
easy way, disconnect the battery form the positive terminal for a about 5 min. resets the ECU altogether...another way is there's a fuse the fuse box under the hood, it does does the same thing. you pull the fuse and resets eveything...but im not sure which on it is on yours..
Old Sep 18, 2005 | 09:37 PM
blhatfield's Avatar
I tried that and it did not work. Is there anything else to try.
Old Sep 18, 2005 | 09:56 PM
Theres a self-diagnosis system in the SRS unit. If you light is coming on, them there is a malfunction in the system.
Old Sep 18, 2005 | 10:00 PM
blhatfield's Avatar
Found a sequence for resetting the light and it worked. Light is no longer on. Thank you
Old Sep 19, 2005 | 09:16 AM
ngoti 8tor's Avatar
ORIGINAL: blhatfield
Umm, maybe you could share that sequence with the rest of us, so that we know also.
Old Sep 19, 2005 | 10:04 AM
Remmy's Avatar
Id get that checked since when that light comes on it means that your airbag wont deploy.
Old Sep 19, 2005 | 11:07 AM
Chimera02EX's Avatar
Yeah that sequence would be great, I hate looking at my SRS light.
Old Sep 19, 2005 | 12:09 PM
blhatfield's Avatar
I found it Here
Old Jan 31, 2007 | 03:05 PM
blitzburghnut's Avatar
would it be to much to ask where you found it . the link does not work any longer . i need to know how to turn-off srs on a 96 civic. no air bag was deployed but, it did take a little jolt . which is why i believethe sensor wentoff.
