Need help in the next hour
Old Sep 21, 2005 | 04:55 PM
97civicturbo's Avatar
Default Need help in the next hour
Okay I need to get an oil return line fitting welded into my oil pan and I need to take it someone in the next hour. I just have one problem, there are two fittings, one to the turbo, one to the oil pan. One is kinda L shaped and one is just straight, anyone have a clue to which one goes to the oil pan or if it even matters??? which im sure it does otherwise they wouldn't be different lol. Please help if you know for sure! thanks all
Old Sep 21, 2005 | 08:13 PM
fast93civic's Avatar
Default RE: Need help in the next hour
ok, looking at my turbo, id say that the L shaped fitting should be the one going in to your turbo.
Old Sep 21, 2005 | 08:33 PM
ngoti 8tor's Avatar
The straight fitting will go on the side of your oil pan near the bottom, therefore I agree with fast93civic about the "L" shaped fitting going on the turbo. I read some info on installing a turbo, that's how I know about the fitting on the oil pan.
And you're doing it the right way to get it welded onto the pan, so that it can't come loose and leak.
Old Sep 21, 2005 | 08:35 PM
AWESOME!!! thanks guys
2000Ex
May 11, 2009 02:33 PM
jchc413
May 8, 2009 03:03 PM
antonio
Sep 1, 2007 10:20 PM
05HonVic
Apr 7, 2006 04:49 PM
Marty
Jan 1, 2006 07:44 PM
