Upgrade Questions?!?
Hi I have a 1995 Honda Civic and I have bought a turbo kit, intercooler kit, i am putting a s300 chip in it, and cold air intake. everything else is stock, is there anything that is a must or good to upgrade?
How are you going to use a cold air intake with a turbo? An exhuast upgrade would help your turbo to spool up faster. Are you running stock boost? If so, I dont think you need any thing but to install it right. A good idea would be Walbro fuel pump, and a wideband air/fuel ratio guage, but its expensive. Most people here use a narrow band that gives you a rough idea of where you're at. Also, a boost, and an an oil pressure guage would help.
and you'll want an egt gauge(exhaust temp gauge) to make sure you're not running to hot. is the s300 chip programmable??? If not you'll need an fmu, and if you have the money get an aftermarket clutch, stage III. How much boost are you planning??
Stumasters
Mar 19, 2007 01:59 PM
