motor swap choice
Old Sep 25, 2005 | 10:48 PM
barryscivic's Avatar
Default motor swap choice
i have a 88 hatch dx i was wondering which swap could i get for around 1200 that will be better than my 92 horses
Old Sep 26, 2005 | 08:50 AM
ngoti 8tor's Avatar
Default RE: motor swap choice
Let's see......there's:
ZC
D16A8
D16A9
B16A1
B18A
B17A
B18C5
Have fun!
Old Oct 1, 2005 | 05:36 PM
dvanvught's Avatar
Dont forget about all the screwing around changing from dpfi to mpfi. It could easily run you way more than that if you have to pay someone to change the wiring up for you if you can't do it yourself. Make sure you consider all the expenses and not just how much the motor is. It's easy to find a motor but not always easy to get it to work.
Old Dec 12, 2005 | 06:05 PM
ef4life's Avatar
try a d16z6, it will bolt in, has vtec, and pretty good parts selection, can find cheap. or just do a head swap. i would suggest to convert to obd 1 with a conversion harness from www.boomslang.us. you can get a obd0 dpfi to obd1 mpfi harness with three sub harnesses built in so you don't have to repin the ecu plugs. the wiring took me and my friend about 2 hours to do a little longer if you want to loom all the wires and make it look pretty. it started right up first try, the only problem i have is i need to clock my tps sensor.
Old Dec 12, 2005 | 06:10 PM
ef4life's Avatar
i just leave the tps unpluged for now, it runs perfect without it
lilpurplecivic94
Sep 24, 2006 08:06 PM
lilpurplecivic94
Sep 24, 2006 06:39 PM
97civicturbo
Apr 7, 2005 11:53 AM
jwsimons
Mar 31, 2005 10:59 PM
jey_253
Mar 29, 2005 04:51 PM
