What is a H-brace
Old Dec 16, 2005 | 09:50 AM
Talon585's Avatar
Default What is a H-brace
Like the title says and if a H-brace is worth it.
Old Dec 16, 2005 | 10:09 AM
Chimera02EX's Avatar
Default RE: What is a H-brace
It adds extra stiffness to the front suspension, and as for worth it, depends on if your willing to spend the money. For AutoX I'd prolly say yeah.
Old Dec 16, 2005 | 10:45 AM
Talon585's Avatar
But what about if the car is lowered cause im assuming that it bolts up under the engine right. Wouldnt it hit the ground
Old Dec 16, 2005 | 12:44 PM
Unless you have <2 inches of clearence no it won't, these things are measure in mm width. It may however hit your header "B" pipe. I actually just ordered a Tanabe "H" brace, they call it underbody brace. I should get it before Christmas I'll post and take pictures after install. By the way for you 7th gens that might also be interested in an H brace, optionsimport.com has an error on their website listing our brace for ~$75, I checked Tanabes site, the MSRP is $198. now they did charge like $40 bucks for shipping, but that is still a steal, just a lil FYI before they fix it.
Old Dec 16, 2005 | 12:56 PM
Talon585's Avatar
You think it would be alright for DD
Old Dec 16, 2005 | 01:05 PM
Yeah if anything it'll improve your handling.
Old Dec 16, 2005 | 01:10 PM
Talon585's Avatar
Can you have both the H-brace and front lower tie bar or only one for your car. Sorry for so many questions, I dont know too much about suspension stuff.
Old Dec 16, 2005 | 03:44 PM
civicexracer's Avatar
$200 for an h-brace is a lil pricey...u can get i think megan racing h-braces on ebay for like under $70 shipped. if u do wana spend about $200 on improving ur suspension, try and find a sway bar, thats the best thing to stiffen ur suspension for the money...as far as having both h-brace and low tie, im not 100% sure but i think u can have both.
good luck with everything!
Old Dec 17, 2005 | 06:22 PM
Talon585's Avatar
I completely forgot about sway bars. Can you have a tie rod, h-brace, and a sway bar up front.
Old Dec 17, 2005 | 06:35 PM
OK from what I've read on 7thgenciv the H brace replaces the front lower tie bar, but you CAN still have sway bar, might have to do a bit modification with an aftermarket sway bar. It could be possible to have both H brace and lower tie, but I know the H brace will bolt up to the same screws the lower tie will.
