Engine swap help
Old Dec 19, 2005 | 01:18 PM
Profeesionul's Avatar
Default Engine swap help
I have a 91 honda civic dx hatch and I want to put a 93 honda civic ex engine into it is there any special parts that I need to swap engines. I know it will fit just need to know about additional parts and where I can get them for cheap if i do need any
Old Dec 20, 2005 | 04:46 PM
finalimpact's Avatar
Default RE: Engine swap help
if just replacing the engine itself, intake manifold gasket and exh manifold gasket. although you may want to consider converting to mpfi at the very least. also some will say you may also want to convert to obd1 and use a p28 to run vtec. personally im cheap, run turbo edit and use the one wire vtec option.
Old Jan 31, 2006 | 11:09 AM
Crook_EG8's Avatar
i have a 93 EG8 civic (4door d15, non vtec) and i recently came across a 87 prelude SI which has the old *** B20, well i want to swap the B20 into my EG8 . i looked for the engine swap info and i found that it will bolt directly up using the stock mounts. but i need to kno, will i have to find a new tranny or can i use the one from my D15? i pretty much have the whole car so what else will i need
Old Jan 31, 2006 | 04:58 PM
eh im not so sure about that one. that style b20 sits in the bay kinda like an h22. from my understanding the swap isnt possible but in my eyes anything is possible.
Old Jan 31, 2006 | 05:33 PM
ef4life's Avatar
to swap in the 93 engine, you need to convert to mpfi. the only parts you really need to make it work is a 88-91 si throttle cable because the stock one is to long. if you decide to convert to obd1 check out www.boomslang.us or www.rywire.com these sites sell conversion harnesses or complete custom engine harnesses to make your swap much easier.
Old Feb 2, 2006 | 12:34 AM
Kappa22's Avatar
No, the D15 tranny will not work.
chbulldogs11@msn.com
May 27, 2011 09:05 PM
skibum853
Nov 18, 2007 09:40 AM
badboy4life
Sep 1, 2007 08:28 AM
Kingzlei
May 5, 2007 04:06 AM
silvr63vet
Dec 4, 2006 03:55 PM
