Argh, noise from rear wheel
Old Jan 24, 2006 | 08:03 AM
Toppers's Avatar
Default Argh, noise from rear wheel
At low speeds, I'm hearing a clinking type sound coming from the rear right wheel. It usually happens when turning. The Chilton manual is a lot of help, for troubleshooting it recommends "inspecting the tire for debris", yeah whatever, this is a mechanical noise.
On visual inspection, everything looks tight and connected. Lug nuts are tight. Bad bearing possibly?
Old Jan 25, 2006 | 02:53 PM
Sysx's Avatar
Default RE: Argh, noise from rear wheel
Guess off the top of my head is bearing.
-Jason.
Old Jan 25, 2006 | 03:36 PM
Remmy's Avatar
I was about to say the lugs arent tight but maybe the drums? While driving, pull the ebrake a little to see if the clinking stops.
Old Jan 25, 2006 | 04:51 PM
amg6975's Avatar
Mine does the exact same thing! I'm pretty sure that it's the drum cause it'll do it if I lightly pull the ebrake too. It'll go away and come back every now and then. I pretend like it's not there.[sm=grinangel.gif]
Old Jan 25, 2006 | 05:30 PM
mxs's Avatar
mxs
ORIGINAL: Toppers
if you speed up or slow down, does the noise speed up or slow down? like something's hitting something as the wheel spins?
Old Jan 25, 2006 | 05:54 PM
AgentofDarkness's Avatar
If the bearings were worn, then the sound would come at like 30mph+.
Old Jan 25, 2006 | 06:32 PM
Toppers's Avatar
ORIGINAL: remington870_20ga
I drove with the ebrake slightly engaged, and the sound got worse. The sound is slowly getting worse over time too.
Old Jan 25, 2006 | 06:36 PM
Toppers's Avatar
ORIGINAL: mxs
I only hear it at the lowest speeds, and especially when turning. The sound goes away completely at 20+ MPH
Old Jan 26, 2006 | 10:36 AM
because you're not applying the brakes. I dont think its the turn's fault that you hear the noise, its the brakes being applied through that turn. I could VERY well be wrong tho.
Old Jan 26, 2006 | 01:23 PM
Toppers's Avatar
It happens turning on/off ramps with no brakes being applied, and cruising through a parking lot with no brakes applied.
