Y8 head on Y7 block?
Old Jan 27, 2006 | 12:57 AM
HustlerX5's Avatar
Default Y8 head on Y7 block?
Will a Vtec D16Y8 head bolt right onto a D16Y7 block?, I've always wanted to go Vtec since I got the car, but I want to know if the head of a Y8 will bolt right in, and if not, what's the proper procedure to get it all together.
Old Jan 27, 2006 | 01:01 AM
Pete's Avatar
Default RE: Y8 head on Y7 block?
yes it will work. Thats called a Mini-Me
The *SEARCH* button can teach you almost everything.........
Old Jan 27, 2006 | 01:13 AM
Cutt's Avatar
There has beeb alot of mini me talk going on around the forum lately. It must be the big thing now. I know I am on the mini me band wagon.
Old Jan 27, 2006 | 01:46 AM
HustlerX5's Avatar
Thanks for the link!, after reading all that I got one question though, What would be the correct timing belt to use for this mini-me, the Y8 belt?
Old Jan 27, 2006 | 02:32 AM
finalimpact's Avatar
your current belt is actually the same size as the y8 belt, tooth count and all. i used to be on the mini me bandwagon. nice thing about it is the sohc vtec cams are cheaper than non vtec sohc cams. although i prefer now to stay non vtec.
Old Mar 11, 2006 | 10:08 PM
yaserkali's Avatar
when you say the vtec heads, are you only talking about the piston heads? What about the actual v tec system? I have a D16Y7 - what kind of power gains in hp from changing to the heads you mentioned? Where can I get those from and what parts would I need specifically....
Old Mar 12, 2006 | 09:00 AM
jusplayn85's Avatar
ORIGINAL: yaserkali
A mini-me swap consists of swapping your cylinder head with a v-tec cylinder head, usually the z6 or y8, depending on your future plans for the car. Also swapping the computer and running a few wires to the v-tec solenoid and a few other minor details.
Old Mar 12, 2006 | 09:02 AM
jusplayn85's Avatar
ORIGINAL: HustlerX5
I'm pretty sure the belt you use depends on which head your swapping in. on the d15b8 block with the z6 head, I used the z6 belt. But I can't guarantee that will work for all the swaps.
Old Mar 12, 2006 | 09:19 AM
yaserkali's Avatar
OK....If I get D16Y8 cylinder heads, the vtec solenoid, wiring and an intake manifold from an EX - what are the power gains? approx? know any where I can get Y8 heads from? ANything else I need?
Old Mar 12, 2006 | 09:34 AM
Kedawei's Avatar
Y7- 106@6200 103@4600
Y8- 127@6600 107@5500
That would be the difference. Get the Y8 headgasket also. Parts can be had from local junkyards or ebay. Ebay will probably be cheaper.
