Del sol Motor inside a crx?
Old Mar 11, 2006 | 09:41 PM
Jabjabrun112's Avatar
Default Del sol Motor inside a crx?
I Have a 1989 honda crx si and i was wondering if it would be a good idea if i put an honda del sol motor (DOHC vtec) in my crx?
and i wanna put a del sol front bumper instead of my stock 1 is this a good idea?
Old Mar 12, 2006 | 07:37 PM
Kappa22's Avatar
Default RE: Del sol Motor inside a crx?
Don't use a Del Sol B16, since they're OBD-I or -II. Just use an SIR-I B16A from an 88-91 JDM Civic SIR. It'll bolt right in and will make the same numbers.
Old Mar 14, 2006 | 04:30 PM
If i put the Sir 1 would i have to change the trans, and the driveshafts?
Old Mar 14, 2006 | 04:34 PM
ef4life's Avatar
you can get a complete motor swap that will come with the trnnny axles, ecu etc. and a del sol front bumper will not work on your crx
Old Mar 14, 2006 | 04:42 PM
what website?
Old Mar 14, 2006 | 04:45 PM
ef4life's Avatar
Old Mar 14, 2006 | 04:52 PM
should i get it with the Lsd or without?( i really dont evevn know what Lsd is)
Old Mar 15, 2006 | 01:13 PM
ef4life's Avatar
lsd if it is in your price range. it will give traction to both wheels under accelration, unlike an open differential which will let you do a one wheel peel
Old Aug 2, 2007 | 08:24 AM
crsoardREX's Avatar
I'm running a 94 Del so VTEC in my 89 si rex. Obd 1 and no biggy. it runs well and I run a p-30 ecu. u could use a p-28 ecu, if u use a 88- 91 b-16a u need either a PR3 or PWO ecu cause they are obd0.
Old Aug 2, 2007 | 08:51 AM
ef4life's Avatar
this thread is over a year old
livejamie
Aug 12, 2011 06:53 AM
Faramire
Aug 1, 2010 11:42 AM
99silverSI
Mar 13, 2008 12:13 PM
92lude
Aug 11, 2007 04:05 PM
macchu43
Mar 17, 2007 09:00 PM
