good handling without lowering
Old Mar 20, 2006 | 07:21 AM
00canSI's Avatar
Default good handling without lowering
I want to lower my civic, but the underground parking ramp at my apt is so steep I scrap the underside at the bottom even if I'm on a diagonal. So my lowering is kind of out of the question right now, but would it still be beneficial for me to upgrade my shocks, and put upper and lower strut bars and upper and lower tie bars. Also, do you really need upper and lower or will it make a huge difference to just have upper, or just have lower?
thanks, and any other ideas would be appreciated.
Old Mar 20, 2006 | 07:29 AM
mentaldis0rder's Avatar
Default RE: good handling without lowering
sway bars below.. and strut bars for top.. also u can get adjustable coilovers and keep stock ride with better quality of spring.. and lower them later
Old Mar 20, 2006 | 09:00 AM
ef4life's Avatar
polyurethane bushings made the biggest difference i ever felf on my car, your car is a lot newer i am assuming so your bushing won't be as worn as mine were
Old Mar 20, 2006 | 01:34 PM
Kappa22's Avatar
Strut and sway bars are a must. Also, you can add some relatively inexpensive dampers to your car with the OE springs to tighten it up. Tokico HP's top the list.
Old Mar 20, 2006 | 04:20 PM
Nail I3unny's Avatar
H&R OE springs keep you at about stock height but theyre stiffer than stock springs.
Big T
Feb 27, 2006 10:28 AM
stick only
14
Dec 1, 2005 08:35 AM
syrusstephens
Jun 25, 2005 08:45 PM
frewcivic
Apr 22, 2005 04:18 AM
CivicCrazy
Jan 11, 2005 11:51 PM
