wrong engine
Old Mar 25, 2006 | 10:46 PM
greencivic's Avatar
Default wrong engine
i've got a 1993 honda civic ex the under the hood label say's it should have a d16z6 but ever since i've bought it came with a d15zi i believe is a non v-tec engine from a vx cause it say's it the valve cover it runs real good the only problem that when i took it for a california emmissions test it failed because to many hydrocarbons and unburned gas at 2500rpm's at idle is fine .i just wanted to know if the having a non-vtec engine is affecting it .i have a d-15 that is vtec can someone tell me if it's could be compadible with my car thank's for you're time .before i forget i've replaced the idle air control valve ,intake air temperature valve,o2 sensor and caalitic converter.
Old Mar 26, 2006 | 02:42 AM
Marty's Avatar
Default RE: wrong engine
are you getting a check engine light and if so are you running the 92-95 p28 sohc vtec ecu. If that is what is running your car you will emmit to many hydrocarbons and unburnt gas at around 2500rpm being the d15z1 is running on 8 valves up untill then and the ecy is feeding fuel for a 12 valve setup.
Old Mar 26, 2006 | 08:16 PM
97civicturbo's Avatar
how did you make sense of any of that lol?
Old Mar 26, 2006 | 10:17 PM
greencivic's Avatar
would my d15b v-tec work in my car
Old Mar 26, 2006 | 10:40 PM
Marty's Avatar
What d15 vtec do you have?
If it is a JDM D15B then yes it will work fine
Old Mar 26, 2006 | 10:55 PM
greencivic's Avatar
yes it's a jdm thank's for the help i will swap them an let you know how it goes in the test after thank's again .
Old Mar 26, 2006 | 11:31 PM
Marty's Avatar
No problem at all man, I responded to your email and if you have any questions at all please stay in contact with me as i am pretty sure I can help
Daniel1274
Jul 22, 2009 10:49 AM
10isAce
Mar 15, 2007 01:39 PM
hondabboy
Jan 31, 2005 11:21 PM
Mad7s
Dec 15, 2004 09:01 PM
White_Devil
Aug 19, 2004 11:48 PM
