Poly Bushings
Old May 14, 2004 | 12:57 AM
fiveover's Avatar
Default Poly Bushings
Where can I get some poly bushings for my sway bars. My 97 Civic coupe has 136,000 miles and I'm thinking this would be a cheap way to stiffen my cornering.
Old May 14, 2004 | 09:57 AM
slim11420's Avatar
if you are going to do it you might as well just get an entire bushing kit....it is going to help your handling SOOOOOOOO much! By now, with a 136K onyour car....the nice little rubber bushings that came from the factory are damn near destroyed....might as well do it all at once...check here for a kit</P>
http://www.nopionline.com/nopistore/...cfm?vpcid=474& amp;vcatid=0010&amp;vcatyear=1996&amp;vmodelid=020 &amp;vmake id=140&amp;vL1id=0&amp;&amp;vtitle=HONDA%20Civic%2 01996 </P>
</P>
Old May 14, 2004 | 11:35 AM
fiveover's Avatar
Thanks for the information. I don't see anything for a rear sway bar. Is this called the lower compensator bar on a Honda?
Old May 15, 2004 | 01:22 AM
fiveover's Avatar
I found a 19 mm rear anti-sway bar. Is this going to make my ride too stiff for daily driving. Also does anyone know if the stock front anti-sway bar is 22 mm?
Old May 16, 2004 | 10:58 PM
slim11420's Avatar
http://www.nopionline.com/nopistore/...cfm?vpcid=472& amp;vcatid=0010&amp;vcatyear=1997&amp;vmodelid=020 &amp;vmake id=140&amp;vL1id=0&amp;&amp;vtitle=HONDA%20Civic%2 01997 </P>
Check this out</P>
Old May 22, 2004 | 12:15 AM
hoody1982's Avatar
Default RE: Poly Bushings
ORIGINAL: fiveover
a bigger front sway bar will introduce more understeer and a bigger rear swaybar will introduce oversteer, therefore if you replace one replace them both preferably by buying them in a kit. With that said 19mm shouldn't be too stiff for daily driving but like I said, if you replace it replace the front as well.
Old Jun 28, 2004 | 03:51 PM
how difficult are these bushing kits to install, am i going to need a press?
Old Jul 13, 2004 | 09:10 AM
iNTRuDeR's Avatar
I'm looking at this too.
How hard are they to replce.
The bushings I mean.
I've considered a front top strut bar, but the polys are lokking like a good mod too.
Old Jul 13, 2004 | 09:24 AM
polo708's Avatar
go to www.suspension.com
or call (800) 291-5340, ask for Bruce. He's awesome.
they have **** loads of poly bushings!
Old Jul 16, 2004 | 08:21 AM
iNTRuDeR's Avatar
Thanks,
they've got a good site.
