Poly Bushings
if you are going to do it you might as well just get an entire bushing kit....it is going to help your handling SOOOOOOOO much! By now, with a 136K onyour car....the nice little rubber bushings that came from the factory are damn near destroyed....might as well do it all at once...check here for a kit</P>
http://www.nopionline.com/nopistore/...cfm?vpcid=474& amp;vcatid=0010&vcatyear=1996&vmodelid=020 &vmake id=140&vL1id=0&&vtitle=HONDA%20Civic%2 01996 </P>
</P>
http://www.nopionline.com/nopistore/...cfm?vpcid=472& amp;vcatid=0010&vcatyear=1997&vmodelid=020 &vmake id=140&vL1id=0&&vtitle=HONDA%20Civic%2 01997 </P>
Check this out</P>
ORIGINAL: fiveover
I found a 19 mm rear anti-sway bar. Is this going to make my ride too stiff for daily driving. Also does anyone know if the stock front anti-sway bar is 22 mm?
go to www.suspension.com
or call (800) 291-5340, ask for Bruce. He's awesome.
they have **** loads of poly bushings!
