Polishing Enkei RS6 rims
Old Apr 15, 2006 | 02:16 PM
glada96EX's Avatar
Default Polishing Enkei RS6 rims
Are these coated? I bought the mothers poloish and powerball and it says a black residue should immediatly appear, and if not, there coated and should stop use. Well I tried it and there was not any residue. What type of polish/cleaner should I use then?
Old Apr 17, 2006 | 11:25 AM
jake11375's Avatar
Default RE: Polishing Enkei RS6 rims
If they are clear coated you can use something like Mother's clear coated wheel polish (you can get it at Pep Boys) It cleans and polishes at the same time. Make sure you don't use anything acidic to clean them with. Non-alkaline is best as acid eats away your clear coat. Soap and water works just fine as well. The metal itself remains polished and perfect as long as the clear is not damaged. However, the clear coat tends to yellow and needs polishing to keep the shine. Good luck...
Old Apr 18, 2006 | 10:44 AM
mill$civic's Avatar
i just got rims with a gun metal finish..soap and water works great
00EX_Menace
Nov 22, 2009 12:29 PM
Good_On_Gas
Mar 28, 2008 12:09 PM
speedyturtle
Jan 16, 2008 05:49 PM
dub54929
Aug 20, 2005 08:32 PM
steven10
Apr 4, 2005 11:29 AM
