changing clutch
Old Jan 2, 2005 | 06:02 PM
jwsimons's Avatar
Default changing clutch
are there any changes in the clutch from '88 to '91. i was checking clutches online and they say to change to a '91 flywheel to upgrade your clutch. i'm needing a clutch now mine is slipping all over the place, and would like as much info before i change it, also have available a '91 crx 5 speed tranny , will it bolt right on?
Old Jan 3, 2005 | 09:03 PM
fast97's Avatar
Default RE: changing clutch
Call honda in your area and ask them if there is a differance in the two. This is your best bet they help me out alot in my area. They know me buy namr though so that could help but they should help you.
Old Jan 6, 2005 | 08:51 PM
Kappa22's Avatar
I believe they changed the clutch (size or # of splines) after 88, but I could be wrong. Also, I think the later 4G CRXs use different sized clutches than Civics. You definitely want to double check all that though.
Old Jan 9, 2005 | 12:32 AM
jwsimons's Avatar
absolutely correct all changed, so, got new flywheel , clutch and transmission, now i have a noise i cant figure out, but the five speed is excelent, just have a couple of bugs
thanx
jonathan
Old Jan 11, 2005 | 03:01 AM
jwsimons's Avatar
well the bugs turned out to be a rub in the flywheel at the inspection cover, gave it a little tweak with a screwdriver and noise is gone for now, what could rub there that does not rub any where else?
Old Jan 11, 2005 | 08:58 AM
ilinihonda's Avatar
Did you check your cable adjustment on the tranny? If it is too loose it will make noise when the clutch pedal is up.
Old Jan 12, 2005 | 07:22 AM
jwsimons's Avatar
ya, tried clock and counter both, slight change only. got appointment for new exhaust on friday, i'll be able to have a good look at it while its up
tuboflard
Jul 17, 2011 11:22 PM
skimmy_jimmy
Mar 6, 2008 02:30 PM
DJAngelicon
Jun 30, 2007 03:05 PM
HARI.
Oct 8, 2006 09:46 PM
civic^2
Aug 22, 2006 10:46 PM
