changing clutch
are there any changes in the clutch from '88 to '91. i was checking clutches online and they say to change to a '91 flywheel to upgrade your clutch. i'm needing a clutch now mine is slipping all over the place, and would like as much info before i change it, also have available a '91 crx 5 speed tranny , will it bolt right on?
I believe they changed the clutch (size or # of splines) after 88, but I could be wrong. Also, I think the later 4G CRXs use different sized clutches than Civics. You definitely want to double check all that though.
absolutely correct all changed, so, got new flywheel , clutch and transmission, now i have a noise i cant figure out, but the five speed is excelent, just have a couple of bugs
thanx
jonathan
thanx
jonathan
well the bugs turned out to be a rub in the flywheel at the inspection cover, gave it a little tweak with a screwdriver and noise is gone for now, what could rub there that does not rub any where else?
tuboflard
Jul 17, 2011 11:22 PM
skimmy_jimmy
Mar 6, 2008 02:30 PM
HARI.
Oct 8, 2006 09:46 PM
