ecu?
Old Jan 3, 2005 | 07:33 PM
fast97's Avatar
Default ecu?
Any body know if there is an ecu for the hx models and where can i get it?
Old Jan 3, 2005 | 08:24 PM
XCM828's Avatar
Default RE: ecu?
[sm=icon_stickpoke.gif]
Uhhhhhhhhh you should already have an ecu.
Old Jan 3, 2005 | 08:38 PM
fast97's Avatar
Default RE: ecu?
Well i do just want to upgrade stock ecu. My car would do almost 200 mph if it had the power to pull it cause of the trans. At 80 mph i am sittin just under three grand.
Old Jan 3, 2005 | 08:45 PM
XCM828's Avatar
Default RE: ecu?
Well yeah any car can go 200 mph if it had the power to do it. I highly doubt an ecu upgrade is gona give u that kind of power. Look into Hondata.
Old Jan 3, 2005 | 08:49 PM
fast97's Avatar
Default RE: ecu?
Tahats not what i am sayin iwnt to find an ecu to make my air fuel ratio a little more rich cause it is lean. not any car can do 200. You are tellin me an ex will do 200 on stock trans.
Old Jan 3, 2005 | 09:21 PM
XCM828's Avatar
Default RE: ecu?
Like I said, look into Hondata.
Old Jan 3, 2005 | 09:34 PM
Default RE: ecu?
if you richen the ecu more than it is now, its not going to give you power. its about balence, not just dumping fuel in. get a head from an ex and do the swap. and youre not going to hit 200 with that trans. the gear ratios may be close to possible(probably not), but progress group(i think) built an si with a built b-series supercharged to compete in the land speed race, and they hit just over like 205.
Old Jan 4, 2005 | 08:06 PM
fast97's Avatar
Default RE: ecu?
Thanks for the help. I has an upgraded ignition what i want is for it to run at the ideal air fuel ratio. My guage say i am lean
Old Jan 4, 2005 | 10:50 PM
fast97's Avatar
Default RE: ecu?
I like my D16Y5 head i get about 38 mog on the Highway which is nice. I dont know if you know about the HX but it has 2 cam profile on the intake side. But when you hit 3000 rpm it changes to the other profile to give more power less econmy. It is like a frirst vetc. do you se what iam sayin
Old Jan 4, 2005 | 11:44 PM
Default RE: ecu?
yeah, its built around the same idea as the "normal" vtec, but is focused on economy, instead of power.
