water pump for mini-me
Old May 17, 2006 | 01:45 AM
crxken's Avatar
Default water pump for mini-me
well, hopefully someone can give me some of their experienced knowledge..
i have an a6 motor and am going to do a mini-me swap with the z6 head. my question is:
which water pump do i buy? do i buy the z6 or a6 water pump?, also will the z6 pump fit the a6 block? the reason is, i went to the autozone and asked to compare the two waterpumps. one of them had a few minor differences. one of the holes were bigger than the other.
and, should i ask for a water pump from a civic ex or a del sol. i believe the del sol also had the z6 engine.
PLEASE HELP me on this.
thanks everyone.
Old May 17, 2006 | 04:10 PM
ef4life's Avatar
Default RE: water pump for mini-me
the water pump bolts to the block, so go with the a6 one
Old May 17, 2006 | 09:29 PM
crxken's Avatar
so does that mean i have to get an a6 timing belt too?
Old May 17, 2006 | 10:12 PM
finalimpact's Avatar
timing belt is the only thing you need to change, either the z6 or y8 timing belt will be fine. but if im not mistaken the a6 and z6 water pumps are the same. the y8 water pump is different.
flcb7
Nov 3, 2010 05:21 PM
zz28zz
Sep 18, 2005 05:09 PM
smokingemcee
Aug 9, 2005 10:36 PM
bartonmd
Dec 17, 2004 12:14 AM
jjgarcia
Aug 22, 2004 07:39 PM
