Need a list of stock turboed cars!
Old May 23, 2006 | 02:31 PM
slvcivic00's Avatar
Default Need a list of stock turboed cars!
Ok so I want to do a home made turbo set up on my Civic, mainly using junkyard stuff. So what types of turboes came off of what cars, for example: TD05-14b (gen. 1 eclipse). I am looking for a junkyard T3 turbo to strap onto my single cam civic. Any info on this stuff would be great, thanks.
Old May 23, 2006 | 03:24 PM
Nail I3unny's Avatar
Default RE: Need a list of stock turboed cars!
id rather go with a new garrett T3 turbine
but as for your question...DSM turbos and WRX turbos are the best stockers IMO.
Old May 23, 2006 | 06:30 PM
slvcivic00's Avatar
Yeah good call on the DSM units, however they are too small, I want alittle larger turbo that will spool later, thus helping on fuel economy not having the BOV going off in between stop lights and making power to red line. Also the WRX turbos are harder to find, more expensive and harder to fabricate piping to.
Old May 23, 2006 | 10:16 PM
riceburner700's Avatar
i know that ford put t3's in some of there cars back in the day, i dont know which cars they were but just do some research and one other thing thats cool is that they are 5 bolt downpipe flanges to
Old May 24, 2006 | 07:50 AM
Clean98EX's Avatar
ford put them in the thunderbird super coupe. you could find one of those pretty easy and its a good sized T3 turbo.
Old May 24, 2006 | 11:38 AM
slvcivic00's Avatar
Good info guys, keep it comin, if they junkyard doen't have these cars then I need other cars as back-up. Thanks
Old May 24, 2006 | 01:32 PM
what about 3000gt's? the twin turbo ones, dont know what turbo is on them but could probably use one of them...
Old May 24, 2006 | 02:17 PM
neon3kgt's Avatar
saabs? volvos? VWs
Old May 24, 2006 | 02:20 PM
lilpooh21186's Avatar
i used an ihi turbo for my 95 civic from a ford probe spools up by 2800 is set from factory for 7psi
Old May 24, 2006 | 03:04 PM
MY99SI's Avatar
no matter what turbo set up u want your goin to need a BOV wheither it be plumbed back into the intake tract or not you need one. compresser surge is not good for the compressor blades and can eventually kill a turbo. compresser surge is when you close the throttle and the pressureized air that jus left the compresser housing has no where to go since the throttle is closed, where else does it go??? back where it came from. it damages the thrust bearings inside the turbo and eventually causes it to fail.
