Bad alternator??
Old May 29, 2006 | 09:18 AM
MrAngryclown's Avatar
Default Bad alternator??
Last week I was driving, all of a sudden the car felt a bit strange. The "SRS" ( airbag light ) came on I pulled over and let off the clutch, at that moment the car died. I spoke to a friend and he suggested to remove the fuse from my aftermarket stereo. After I did the car started back up, I was able to get it home. Prior to the incident I had been noticing the car was struggling to start every once in a while. Currently the car is starting but it takes a few secs, come to think of it i should go check again today. So my question is, Was this an alternator problem part on by my aftermarket stereo? and if so What are my options now, a bigger alternator?, a stock alternator with a capacitor?
1998 Honda Civic EX
Old May 29, 2006 | 11:14 AM
AgentofDarkness's Avatar
Default RE: Bad alternator??
How big is the aftermarket stereo? Start your engine and put a voltmeter on the battery. It should be between 13.5V and 15V.
Old May 29, 2006 | 12:06 PM
I have 2 350 watt subs, with front components (i'm not positive of the watts) and rears, its funny b/c I don't think the stereo was even playing when it happened. The lights in my car have been dimmed though since I put in the stereo.
Old May 29, 2006 | 02:53 PM
Phil Mygroin's Avatar
If your airbag light comes on in these situations, it's a good indication your car can't keep up with the electrical demand. Honda airbags tend to set inermittent fault codes when the voltage drops below a certain point. It doesn't take much though, because I've seen them come on when the voltage was as high as 12.2 (engine off). You may have had a surge in the system, and that kicked the light on. So, while your checking the voltage with car running, turn on your accessories one by one and see what happens.
Old May 29, 2006 | 03:34 PM
okthe voltage while the car was running was 13.5 but i have to try it again while turning on all the components.
danstelter
Sep 15, 2013 09:23 AM
burnindesirez02
Jun 30, 2009 06:09 PM
grunge
Sep 24, 2006 09:00 PM
Crazed
14
Sep 15, 2006 11:26 AM
pmitch100
Dec 8, 2005 04:08 PM
