newer suspension into a 86 sedan
Old Jun 4, 2006 | 08:56 AM
salej60's Avatar
Default newer suspension into a 86 sedan
I can get suspension/ coilover from a 97 model of a friend's civic
What kind of work would need to be done for it to fit?
What extra parts do I need?
Old Jun 4, 2006 | 05:19 PM
ef4life's Avatar
Default RE: newer suspension into a 86 sedan
the easy answer is no. i believe your cars front uses torsion bars (no coil springs) and the rear has a twist beam axle but anything is possible if you fabricate.
to lower your car you might be able to get springs for the rear axle aftermarket for you car, or i know you can for a 84-87 crx (they might not be the same, but could work.
the front you can crank down your torsion bars to lower it a bit.
Old Jun 5, 2006 | 10:49 PM
finalimpact's Avatar
i beleive the sedan doesnt use torsions up front but i could be wrong. my buddies 83 civic hatch uses springs and struts up front. but the 97 suspension wont work.
2slo4u
Jan 26, 2007 08:38 AM
Akus
Oct 24, 2006 11:08 PM
sully
Oct 24, 2006 11:39 AM
bebeh
EK Swaps
Nov 5, 2005 12:30 AM
ricerflag
Mar 12, 2005 07:11 PM
