Canada, Over Seas & Elsewhere Not from the states? Everywhere else post here.
bits for sale
Old Jul 10, 2006 | 02:32 PM
crxcrazy's Avatar
Default bits for sale
these parts are not needed anymore as i have just sold my civic for a crx
brand new carbon fibre bonnet with air vent for HONDA CIVIC 1992-1995
£350 delivered
brand new carbon fibre spoiler spoon type for HONDA CIVIC 1992-1995
£190 delivered
brand new angel eye headlights for HONDA CIVIC 1992-1995
£160 delivered
brand new unwanted gift Apexi safc2 safc air fuel ratio computer silver
The Super AFC II (Air Flow Converter) is the industry standard for sub computer fuel control. The S-AFC II is designed to fine tune and "squeeze" power out of existing engine setups by allowing the user to modify the fuel curve with precision accuracy. Since the act of simply bolting on performance products does not make maximum horsepower, the S-AFC II allows the user to calibrate the fuel system in accordance with performance upgrades as they are installed. The AFC modifies the air flow meter/ pressure sensor signal voltage going to the factory ECU (Engine Control Unit) to change the amount of fuel injected. The S-AFC II utilizes a VFD (Vacuum Florescent Display) to display critical data in three different modes.
Features for the S-AFC II include:
Newly designed case and user interface, single button menu navigation, 12 point fuel correction in 200 RPM increments, data storage for two different correction maps, password protection, integrated knock monitor, and 4 different display options.
The S-AFC II, while not completely universal, comes preprogrammed with 15 of the most commonly used air flow meter/pressure sensor maps. By setting the AFC to one of these programs, the user is able to adjust injected fuel amounts by +/- 50%. 12 user defined RPM adjustment points allow for fine tuning in 200 RPM increments. Fuel can also be adjusted for part or full throttle situations.
The Deceleration Air Flow Correction cures erratic idle problems for Hot Wire vehicles equipped with an open atmosphere blow off valve. The S-AFC II can also display an incredible amount of data including: Air Flow Capacity (Hotwire and Flap Type only), Engine RPM, Throttle Position, Pressure Sensor voltage, Karmann Frequency, and Air Flow Meter Correction.
The S-AFC II displays data in three different modes: Numerical, Analog, and Graph. Numerical Mode allows the user to monitor up to four different parameters in numbers and also shows peak hold values on demand. The Analog Mode displays up to two values in an easy to read meter style display. Peak Hold is also included in this function. The Graph mode offers real time graph plotting with a Ghost map trace feature built in. The graph can replay movement up to 60 seconds
£200 delivered
Old Jul 10, 2006 | 02:36 PM
crxcrazy's Avatar
Default RE: bits for sale
didnt relise this was a american site
Old Jul 11, 2006 | 11:24 AM
mxs's Avatar
mxs
Moved to "overseas" forum for you. Good luck with sale.
Old Jul 11, 2006 | 09:18 PM
my_hidden_romance's Avatar
have u checked pricing for shipping to us?
Tommo87
Jul 21, 2008 01:59 AM
rydnlow1120
12
Oct 16, 2007 05:17 PM
crxcrazy
Jul 10, 2006 02:36 PM
JDMB16CIVIC
Nov 30, 2005 08:51 AM
